Forward and reverse gear
joe agey
I have a 1985 evinrude 150xp model E150stlcos. I have put another lower unit on the motor. It has the same size shift on the lower unit like the old lower unit. I am having problems adjusting the shift lever. Any suggestions on how to adjust this would be appreciated.
joe
brim_buster
Re: Forward and reverse gear
push the shift rod down to get it in reverse, then put shift lever in reverse and attach the 2 rods together.
Did you adjust / set the shift rod height to the correct dimension ?
joe agey
No did not adjust the shift rod it look like it was about the same as the old one. What is the correct dimension for this and do I need to remove the lower unit to adjust it?
joe
Just google -------johnson shift rod height ------To find the dimension.----Set that dimension with lower unit off and re-assemble.-----Measurement is with gearcase in nuetral.
joe agey
I pull the lower unit back off and check the shift rod dimension and it was set to 21 15/16". does any one have a picture of the shift lever on the motor. I need to find out if the shift lever point out to the boat are if it point to the block of the motor.
joe agey
The shift rod dimension is set at 21 15/16" in neutral. With the motor not running I can put it in reverse and it works ok but when I put it in forward it seems that it will not go all the way in gear when I turn the prop. Then I take and push the shift rod forward by hand and it will lock in gear. Any help or suggestions would be appreciated.
Joe
