forward drive/bravo 4
Scott06
Anybody out there using either the Volvo Forward drive or Bravo 4 drive for recreational (aka we're not that good at it...) wake surfing behind an IO boat ?
Was just curious for folks that aren't that Seriou$ about it how does it work out behind a non wakeboard boat? Even if I had the disposable income for a wake boat I wouldn't want to chuck up that level of coin...
Have a 21 ft low hour great shape bowrider that I repowered 7 years ago. I'm very mechanically inclined had a idea of getting the transom and drive to put on this boat. Yes would be easier to by one of the high end bowriders that comes with a forward drive or B4.. but I like building things vs buying them (sometimes to my detriment).
Was looking for feedback if anyone is running such a set up before thinking to hard about a conversion
I know a few people with VP IPS drives. They like everything except needing deeper water than a traditional drive.
If you are going to wakesurf, sure beats planting your face into the props
Scott06
Yeah IPS is a little different. I have a dock/hoist in a shallow cove so having the props in front isnt real appealing either..
paulswagelock
Friend has the Volvo version. Likes it, does ok for a casual wake, and is better than a fixed prop for regular cruising. Loading on a trailer and his lift both required new skills and cautions because of the increase draft.
Scott06
Thanks for your input. i was thinking normal crusie would be better than a V drive.
draft concerns and trailer height are potential issues. It wouldn’t be a cheap project but if it would work would be cheaper than an newer boat… and i like what i have now size wise … plus its paid for.
bruceb58
If you want a forward drive on a boat...sell your boat and buy one with one.
The wakesurfing is going to suck unless you put a lot of ballast in your boat. A 21' boat will not be big enough to get a big enough wake. In addition, you will have to get big tabs to create the wake. Most boats that you surf behind have an automatic throttle control to keep a constant speed.
I have a Cobalt R5 that is also available as a Surf model....even it kinda sucks compared to a real surf boat.
I have surfed behind a number of dedicated surf boats. Even boats that were made just 7 years ago pale to what a newer surf boat creates for a wave.
Good luck finding a Bravo 4. I personally have never seen one on a production boat...likely because Volvo almost immediately sued Mercruiser.
Scott06
Thanks for your comments.
The antea for an R5 or surf boat is not in my cards, plus I like mechanical projects ... hence the thought. Figured some sacks or other mods would be needed as well...
I haven't seen a B 4 sold new or used anywhere so may be a moot point
