Found a sunken boat
bajaunderground
Post up some pictures of it?
I'm not sure why so many people are against raising a boat they find? I would do it just for adventure...if you find a body or "crime scene evidence" so what...call the authorities? As long as there is nothing illegal about raising a capsized, abandoned boat (with good intentions). I would think the situation is easily explainable and completely reasonable?!
Worse case scenario, you've cleaned up a portion of the creek!
Mel Taylor
I'm with you on that one. I'd want to see what's under it and whether it's worth salvaging or not. My guess is that worst case scenario would be having to cut it up with a chain saw and hauling it to the dump.
NYBo
I would report it to the local authorities before you begin any salvage operations.
Not Likely, but it may be a crime scene that someone never wanted found.
You do not want to have to start explaining how you came into possession of the boat that they are searching for when you attempt to title it. At least then you will have an official report that you had nothing to do with its demise.
You also do not want to be the one that rolls the boat upright only to find the owner still in it!
This would be the first order of of business.
A "14' fiberglass boat" covers a lot of ground. If it has construction like a Boston Whaler, it might be worth your time. If it has more "traditional" construction (wood stringers and transom), it might be a lot more trouble than it's worth. But establish ownership rights FIRST.
bassman284
Yeah, maybe. You're an adventurous guy, baja. Me not so much. Actually, I figure worst case scenario is winding up in handcuffs in a small room with no features. But that's just me.
T_Herrod
I would contact the local authorities. Wait for them to check it out. Then if they say it's ok i would begin the removal process.
jbcurt00
Whatever they think they can.
It's certainly NOT the OP's boat, but perhaps they'll think it was in his possession when it sank = theft. Since it's not his boat & he has possession of it after raising it = theft. Maybe it's got oil & gas trapped inside somewhere that starts to leak out once disturbed = toxic spill/EPA fines which if bad enough could get you detained by DNR/Fish & Wildlife.
I wouldn't take a car (or a boat) I found abandoned in a long forgotten field w/out LOTS of leg work first. Why is this any different?
Reminds me of the stupidity involved when someone doesn't want to fix a KNOWN rotten transom, and asks for info, or approval to do a band-aid faux repair. Someone who's never even seen the boat in person or put their hands on it always chimes in to agree it's safe to bolt on a steel plate or 2, then continue to use the boat 'just for the season' or 2.... It isn't.
We all know what typically happens, that boat gets sold to someone who usually has NO idea that the boat is unsafe, and then uses it.
It's bad enough that whoever asked about a band-aid fix is endangering themselves & those that board their boat. But for me the larger problem is that there is now a public record that reflects a bad decision that got someone's approval and who knows how many people will read that & think:
That guy online said it's OK, and it worked for the guy who asked the question, so it'll work for me too.
Why is it difficult to imagine (and suggest) that this recovery should be done correctly? In this instance, w/ a little effort, IMO, the OP could find out what is required of them prior to disturbing a sunken vessel and once recovered, legally gain ownership of it. That might even be possible prior to raising it since the HIN IS clearly visible.
Rant over, my apologies to the OP for the thread drift ^^^
My original suggestion stands: I wouldn't touch it w/out doing some fact checking & asking lots of questions.
