Free Picture Hosting for iboats members Revisited
SpinnerBait_Nut
Re: Free Picture Hosting for iboats members Revisited
Originally posted by mellowyellow:<br />now that I have a floder, how do I add to it?<br />make a new folder for each pic? will try to<br />import one to existing folder...
MY, just right click your picture and then click copy and then go to your folder and paste it.<br />It will transfer it to the folder for you that way.<br />It did for me anyway.
mellowyellow
thanks SBN... tried that, but paste is not an<br />option when I right click on my folder.<br />edit.<br />it just worked??? no idea why? LOL
POINTER94
MY,<br /><br />Try putting your disk in the drive, calling up the photos. They should show up as icon's. Pic and drag the icons you want over on top of your folder. <br /><br />This should copy it into the folder. ;)
mellowyellow
test:<br />
<br /><br /> ftp://iboats@66.136.189.194/mellowyellow/MY2.jpg
ndemge
FTP101:<br /><br />Easy way to do it, is to use Internet Explorer to FTP<br /><br /> ftp://66.136.189.194 <br /><br />It should ask you for a username/password iboats for both<br /><br />(if it does not ask, right click, "login as"<br /><br />Once you are in, you should see everyone's folders. Simply right and select "Make new folder" Give it a name. If you hit enter, and it just says "new folder" Right click that new folder and click "rename" and name it to your name. Do not use spaces!<br /><br />Make your Internet Explorer window NOT full screen. Move it to one side. Now Drag your pictures into your new folder.<br /><br />To VIEW the pictures you have put up, you need to go to the same directory you just created, but via HTTP and not FTP<br /><br />so... http://66.136.189.194/iboats <br />that will show you the directory listing for iboats, you can then click on your name, click on your picture, and copy and paste the link... then come to the forum and insert that inside [img tags so everyone can see it :) <br /><br />seems like a long way to go to get a picture online, but that's what it takes, and once you do it and understand it, it's really pretty quick.<br /><br />Another method is to go to www.download.com and download yourself an FTP client. you put in the ftp address, username and password, and you can select files you want to upload... might make it easier for you.
mellowyellow
whoa! :eek: little large...<br />this is the "widewaters" a natural pond off the<br />erie canal (which is right across the street).<br />great fishin spot :D <br /><br />now SBN, I tried the reg. .
. with<br />no luck. what's the trick buddy?
mellowyellow
nmedge, i was linking directly into my parent<br />directory, not ftp. page. MY bad :)
Matt O
well I added a folder and gonna try to make this work. Man I will be surprised if this works.
<br />
mellowyellow
nice fat, healthy Bass there :D <br />jealous :( ,<br />M.Y.
ndemge
looks like you have it figured out.<br /><br />(I resized that picture down to 780 wide.... it was frigg'n huge!<br /><br />be back monday ITS FIRDAY!!!!! WOOT!
bomar76
ndemge -<br />Tried to upload a pic today but I couldn't log in with iboats/iboats.<br />Problems?
FLATHEAD
I had the same problem this morning. Seems the iboat password is no longer good
ndemge
can't get to the server from here,... routing problem with centurytel... see my tech support thread.<br /><br />server is up, but don't know why you can't log in.<br /><br />I'll be back at the office tuesday, will take a look at it.
ndemge
Ftp access is back up.<br /><br />Brain fart mistake killed it.
Matt O
Is there a server problem with this site, or is it no longer usable. I uploaded a pic and have tried several times to make the picture load in a new post in the fishing forum and can't make it work. I pulled up a prior post where I made pics work and the file name looks like its good. Thanks<br /><br />Matt
Sailor_Vic
NDEMGE, you sir are the man. Relatively new at this internet stuff,but followed your directions and I now have pictures that work.TY.TY.TY.I am currently restoring a 17' sloop to go gunkholing in and would like to document the restoration in progress. Now I have the means. Will post some pictures as soon as it stops raining. But hey it's 70 Degrees,can't complain.Be good and fair winds.
