a guy in my marina has been trying to get his boat running one year, and still no dice, tonight i decided i will lend him a hand,.
1979 Searay 29 foot twins 454 engine serial #961959 firing order 18436572.
where do i start, well he claim he got both block rebuild, now he has water in both engines, milky milky oil, he claim he change the power steering cooler because someone told him that why he gets water in the oil, ha, any to make it short he change the risers and manifold on one engine, today i try starting it but it will not catch but it does turn over.
i took out number one spark plug get the engine to top dead center because it was way off,
i re wire the plugs which was also wrong, boy oh boy,
i try cranking it over again no start, i am getting fuel but it seems as if there is no sparks, why i took the wire from the coil put a screwdriver in the wire ground the screwdriver to the block have him crank it over no sparks, . now what.
last it has a close cooling system, which i think all the hose was just wrong , they have the two hose from the thermostat going to the risers, so all the anti freeze was going over board, when it start. they has no block off plate between one risers and manifold, by the way it has the old logstile manifolds.
it also has points and condenser. now guys if all the hoses was rout totally wrong should that cost water to get in the engines, or if the firing order was wrong will that make the engine spins backward,
dons can you post the diagram for the close cooling system for that engine with logstile manifolds thanks.
