Friscoboater
- Jul 3, 2009
- 3,095
Re: Friscoboater's 1986 Glastron Carlson CVX-18 Complete restoration thread
I hear you Wood.
I actually wet back and read Oops thread again just to make sure I was correct in what I remember... (I am getting older) and oops did use CSM to tab the stringers in with small 5 inch tabs to round the fillet corner and then over lapped it with 1708 straight to the hull and stringer. So there looked to be quite a bit of the 1708 sticking right to the bare wood and hull. Like I said in a previous post, the CSM helps build thickness in the corners so the 1708 will lay down better in the radiuses. The key is not to have air bubbles and have the right amount of resin to wet out the glass.
I have seen ten different ways to build boats, and all of them are 500% better than what was done from the factory.
I respect all of the builders here greatly, and we all do things slightly different.
The CSM stitched to the back of 1708 biax is approx. .75 oz. A lot of people, including me, think this is not adequate for creating a good bond, especially on the first layer attached to the wood and glass hull. I still and will always recommend the added CSM to ensure a proper bond. Having said that, I have no documented evidence that NOT using it leads to de-lamination or failure of the bond. Like I said, Just my preference and lot of others. OOPS was a BIG proponent of doing it this way. I believe he picked this up from ondarvr. As always, It's your boat and your choice. I'm just an...![]()
I hear you Wood.
