Ill try 2 make this as short as possible. 96 112 spl, rebuilt power head. Orig blew up # 1 piston (found stuck thermostat and no active alarm horn)
Rebuilt .020 over, new water pump, thermostats, checked carbs and fuel pump. !st time out to lake, failed to start. Faulty starter, replaced cables and starter. 2nd time (today) started and launched, but no power, failed to get up on plane. Im suspecting faulty coil, which had chuck taken out of it. Have replacement and wires. Im just wondering how to go about identifying problem. Because the motor will sound and run fine on the driveway,,,, but the big test is under load. Im going to inspect plugs, and compression check first, but what next? I have a timing light.
just a little frustrated after spending all day replacing thermostats and still have trouble,,, but at least temp is bout 145 both heads. sorry for long post,, Joe
