I am getting near the end of my patience! The old Johnson 70hp 1977 Seahorse I have, starts well and warms up no problems when it's in my driveway and earmuffs are applied. When in the water it starts up and seems to have problems warming up and when i get going under acceleration, bogs down! If I take it easy on acceleration it seems to gather momentum and runs well. If I stop for a while and then restart the motor stalls under accelaration, if I stop and restart within 5 minutes the motor performs instantly and with no problems!. It will run all day cruizing after it seems to get itself together. I have had it tuned and serviced by 3 seperate marine specialists and they all report what a great old motor. has great spark and advances wonderfully to use a term. Compression is 100 to 125 over the 3 cylynders. Also
have replaced the fuel pump, spark plugs, coils and power pack with no difference.
Still bogging down under constant accelaration, the carby's have also been kitted out. New fuel and fuel lines plus tank!
I am now being told that it could be the butterfly shafts on the carbys being worn, but I seem to see very little movement on them. Remember the jets are pre set so fuel mix adjustement is out of the question.
I am about done! Every where I go is something different for the same original problem and costs are mounting up.
Would Seafoam or a similar product do the trick?
Please end my frustration!! Thanks
