jmznshana
- May 16, 2012
- 35
Re: Fuel capacity issue
So my understanding of this possible foam water logged issue is this. If the boat takes on water essentially the foam will get soaked. If I know or can tell that water got in from under the rub rail anywhere around the boat. (I know it did through the transom area at the least) I can see silicone sealant on a few other areas around the boat and up on the bow area. The foam will get wet/retain water.
The only way to rectify this is to pull the floor and replace the foam? (assuming this is the case)
