The actual first gen EFI engines are slightly better than carbureted engines. By slightly I mean 10% max. The newer DFI engines are 30% or better over carb'd engines.
If fuel economy is a huge concern think about how you boat, what speeds, and what activities you do. And pick the prop that is going to give you the least amount of slip for that activity. Efficiency/economy/slip are all related.
As for this
pckeen said:
#4
Take a look at this link - it has some side by side comparisons.
http://www.boat-fuel-economy.com/mer...umption-liters
Similar displacement engines had higher horsepower in the fuel injected models, but were correspondingly higher on gas - so looks like overall, the fuel consumption on a new carburetted vs. fuel injected motor would be very similar.
I can't imagine that website being very accurate. Diesel engines in the real world work on brake specific fuel consumption, where for all intents and purposes the amount of load does not matter, or effect, overall fuel economy. But gasoline engines do not work that way. On paper they do, but real world conditions change it to much for bsfc to be any kind of accurate. Simply speaking a 5.7 in a 21 foot boat is going to get much better economy than that same engine in a 27 foot boat, and I'm talking rpm to rpm, not speed.
1 thing that stands out though, if it's true, is that Mercs new 4.5 V6 gets worse fuel economy at 250 horsepower than a 5.0 does at 260 horsepower. Kinda makes a 5.0 a more attractive option. More power and better fuel economy.
