Fuel Gauge Woes. Help needed please.
iammarcuse
I have a Key West DC2020 with a 140 Suzuki. It sat for a couple of months and the fuel gauge reads E yet I know it is 1/3 full. It seemed I was getting voltage back from the sender so I tried a brand new gauge. Still nothing. Swapping out the sending unit is a challenge as it is not right under the access hole and will require pulling out pedestal seats and the floor panel. So I want to make sure that is the problem first.
At the sending unit it reads 110 ohm across from sending wire to a known ground. That would seem right on 1/3 tank of fuel with a 230 -33 ohm sender. At the gauge I read 4.8V across the sending to ground. Which again seems about right given V12 at 110 resistance. But clearly I am missing something here.
Back at the gauge I read 4.8V from sending wire to a known ground. I also read 4.8V from the ground wire to a known ground. Does that sounds right? I am not 100% clear on how these circuits in a fuel gauge are supposed to work, so I don't know what to make of that.
I am wide open to solutions here. I must be missing something. Thank you.
dingbat
Fuel gauges don’t operate on 12V.
12 volts comes into the gauge and reduced to operating voltage (~5-8V) at the gauge to drive the meter.
The sender is connected to the ground side of the circuit.
You need to pull the sender to test operation.
iammarcuse
That is good information. Thank you. The one thing I have not checked is if I have a good ground at the sending unit. This is a salt water boat in Florida. I get bad grounds all the time. Especially underneath the floor where the tank is. If the ground is bad I would assume I would be getting nothing. Which is the case. I will check that first before I do anything else.
Chris1956
Sounds like a wiring problem. The sender does not ever get voltage applied to it. The sender changes resistance to ground, as the tank empties during use.
Check to make sure the power (+12VDC) and ground to the gauge are good. Check resistance from ground at the gauge to the sender wire at the gauge. It should be zero ohms.
iammarcuse
Solved. It was a poor ground to the sending unit. I could not trace where the ground went as it is under the floor. So I merely ran a new ground directly to the battery which was my easiest path. All working now. Thanks. Glad I didn't pull the sending unit.
DeepCMark58A
Thank you for coming back letting us know how the issue was resolved, nice to have closure.
