My 21' sylvan supersporster originally came with an 88 Hp johnson spl which ran fine albeit not as fast as I would have liked. I replaced it with an 1982 evinrude 150hp. It runs ok but seems like it has more to give but for some reason, just can't! I eventually replaced the fuel line and bulb from the tank to the engine. Fuel line is 3/8 but the end fitting/clip that connects to the engine is 5/16. Could this slight restriction be the potential cause of the power loss? After all I went from an 88hp 4 cylinder to a 150hp 6 cylinder. Thanks!
