fuel mix
mbhoag
Re: fuel mix
I have 1972 Chrysler 55.
What fuel mix do I use ?
I usually use a mixture of unleaded gas and oil...:D
I would think your Chrysler 55 is the same as my force 125... 50/1 ratio
mrdibs1
Re: fuel mix
40:1 is probably safer for an older motor. If it smokes too much back it down to 45:1.
jerryjerry05
Re: fuel mix
They design the oil and the motors to run 50-1
Too much oil will carbon the rings and there you go that older motor takes a crap,even though you babied it and gave it extra oil.:)
bentle
Re: fuel mix
50:1 mix. 87 octane fuel. To rich and you will gum up your piston rings.
