kd4pbs
- Mar 5, 2012
- 316
Agreed… in an automotive system. I am sure they have been used, but every marine EFI I have had experience with uses a single connection supply from the tank and that is all. I figure they don’t want yet another line to possibly cause hazards or since the tank might be well insulated and buried in a boat versus an automotive system, it might not get adequate cooling and potentially build heat to dangerous levels, especially as the tank gets more empty.
Now that we know the OP has a fuel injected engine, I would recommend ensuring the cooling passages are clear and that cooling water is circulating as designed.
Disregard. I re read his 1st post and it is a 4bbl carb. I guess Mercruiser used an electric pump on those? I would have assumed it would have been a solenoid style pump that doesn’t heat up significantly if so.
