flyhigh123
- Nov 17, 2012
- 112
In this diagram is that elbow looking thing the main cable connector?
You can but there will just be the mating connector in there with nothing to probe. Pull the connector off and measure the voltage at the helm side of the connector.
Did you try following the wire from the ignition switch?
EDIT: Forgot you won't have voltage if you pull connector apart. Would have to jumper main battery feed between connectors.
^ Yes and it sounds like you found the cannon plug in post 83 but just in case the plug end should look something like this for reference,Is the "main wiring harness cannon plug connector at the engine" the Main Cable connector on the diagram?
Yes! Luckily my mechanic didnt have space for me and diligence with your help got me to the end game! back on the water soon.Glad you found the problem and glad you have the correct Alternator too. Patience of working through it all has finally paid off.:eagerness::encouragement::thumb:![]()
Fully agree! Yah it was a tough problem cause the issue was the contact point on the igntion switch, not the wire itself. Just happy to have solved the issue. On top of that, learned a lot, and didnt give up. I have no issues with paying a mechanic to fix something, but if I dont do it myself, i'll never learn.Good news. Those type of problems are tough to find. You had it narrowed down between the ignition switch and the engine which was a huge step.
If you had not had that issue, you would still be running with a miswired fuel pump system and alternator so you got that out of this.
