rothfm
Ensign
- Sep 26, 2006
- 915
Hi All,
My ongoing fuel tank work brought up another question...Pics attached. Not sure if a prior owner did this or not. Original 155 gallon tank had a 3/8 Pickup Bung in tank, with a 3/8 pickup tube.
The topside port on the pickup is 1/4 npt. Attached to this was a manrine brass 1/4" shut off valve ....Then going to a 1/4-to-3/8 barb.
The whole fuel path from bottom of tank to motor is 3/8, EXCEPT for this 1/4" shut off valve. Looking into the shut off, the hole is pretty small. DOES this present a fuel restriction if the systems requires 3/8??
I am buying a true 3/8 Pickup, that has the topside port also at 3/8, and going to keep it all 3/8 all the way through--seems to make simple sense. Isolating the diff metals with a nylon coupler.
Unless someone in the know thinks that 1/4" shut in the sequence makes sense somehow (can figure why it would).
Will be 2 feeds fueling twin 150's.
Thanks for any thoughts. Almost ready to bring my replacement tank to the welder for Bung install and swapping fill/Vents.
