Fuel spitting out motor connector
Mitch/canuck
I've got a '79 6hp Evinrude. When I disconnect the fuel hose to run the carb dry, gas spits back out of the motor. This goes on until the carb runs dry. I've never noticed this before. Do I have a fuel pump problem?
James R
If it is spitting from the motor fuel connector at the engine the seal has gone bad or the spring has failed. Quite common.
F_R
Normal. It's called gravity. There is nothing to keep the hose from draining. That's why in some later year they changed the fuel connector design to include a valve to prevent drainback. You can put the new style connector on yours if it bothers you enough. They are only $51.00
most likely the $0.89 o-ring in the connetor is bad.
nwcove
hate to bring up a point of debate thats been beaten to death in the forums, but why on earth would you repeatedly lean your two stroke out of fuel/oil by running the carb dry? jmo.....it is not a good practice and shortens the life of the motor.
