Fuel Tank/Pick-Up Tube Question
atj51
Re: Fuel Tank/Pick-Up Tube Question
I've removed mine and have the replacement ready to install. Does anyone know if it's mandatory to use a screen on the new pickup tube? I bought a replacement from Moeller and it doesn't have any kind of screen on it. I was told to just cut the tube at a 45 degree angle before installing.
sea6ristle
atj51 - I can't imagine it's mandatory-do you have a water fuel separator in the line? I figure that will catch any tank smutz --I have had my boat 10 years and the (plastic) tank looked pretty free of any debris big enough to be stopped by the screen, so I left it off. But then, I left off the anti-siphon valve too and that is mandatory. Just look for the fireball:eek:
ronwbanker
I have had the exact same problems on my bay boat. The fuel tank is under the top cap in the floor of the boat. I only have a 6" or 8" access hole to get a wrench on the larger nut (1 1/4") and on the top of the pickup tube. But I can not get it unscrewed. Any suggestions if it wont unscrew? If I break it, then Im the one screwed.
sea6ristle
I ended up using a basin wrench --it's the perfect tool for the job. Are you talking about the nut that the pickup tube fitting threads in to? I would'nt (didn't) mess with that. I think I read somewhere that it may be welded onto the tank.
M&M1337
I promised...pics of my tank/pick-up tube. Can anybody tell me how the tube comes completely out?
iI was working on my boat this weekend and had same problem. There is a screen at the end of the tube, pull sharply and it should come out. the screen is what should be holding you back,no filter on mine!!
Smead42
How about another pick up question.
Just got my 95 Scout Dorado out last month from 1 1/2 years in storage with 1/2 tank of fuel. Tried to get gas out my siphon etc. with no luck. Ran down problem to tank pick up. Took the fitting out ( it's 2" under the deck) and that was all that came off just the aluminum 3/8 x 1/4 npt 90 degree fitting. After looking into the tank at the spot where the fitting screws into the tank (had to bore a 1 1/2" hole in the deck), there is nothing except a square end thick aluminum pipe that fills the entire hole under the threads. This pipe has a hole in it that looks to be about 3/8. There is not a sign of a tube, a fitting or anything. I can see that the pipe in the tank curves toward the center of the V tank. I called Scout to find out if there is anything unique about the pick up; they don't know, but ordered a new pick up one month ago. It still has not come in. I just ordered a 24" generic hoping to make it work. Has anyone out there see this problem?
Ayuh,.... Welcome Aboard,.... How 'bout You start a thread of yer own,....
Insteada hi-jackin' this abused Antique...
Smead42
Ok, how about a brief "how to." It's not very apparent!
Ayuh,.... Upper portside corner of the forum page the blue button that says, "Post a New Thread"...
