Fuel water separator install
matt167
I ordered a new OEM mercruiser fuel water separator to install in my boat after I had a pretty severe water in fuel issue ( cut trip short when kicker quit )
My boat has 2 fuel tanks with a selector. Should I keep the selector in place or tie the tanks into the 2 inlets together? I’m also going to hook the kicker motor into the separator as I think it’s actually a better solution on my boat. The kicker tanks only place is strapped to the transom which works but it also easily allows rain water in. I’m thinking I should leave the selector as that makes 2 separate fuel systems
Can I plumb a ball on the outside of the transom to the kicker? Obviously using marine rated fuel line
Chris1956
Gee, remove and siphon the fuel out of the kicker tank and pour off the water.
Spend $10 on an electric fuel pump and siphon the fuel off the bottom of the main tank and pour off the water.
A water separator works by allowing the water to settle to the bottom of the separator canister. If that fills up, water will go to the motors.
matt167
Well yeah oil/ petroleum floats. But if the separator fills up, drain it. Re prime it and keep going… weird thing about oil and water is it doesn’t mix but it can be held together in suspension if it’s shaken or mixed. Hence water seperator
airshot
Of more concern to me....how is the water getting in ? Check where you buy your fuel ! Often folks are getting bad fuel when they buy it if the vendor doesn't take care of his stuff. Years back I had a water issue on a boat I had recently purchased. Water was getting into the fuel tank, checked supplier and fuel was OK, so that meant water was getting into the tank on its own. Checked the hose from the tank vent to the outer vent on the hull. There was no upward loop on the hose to prevent water from coming into the outer vent and running into the tank thru this vent hose !
Adding the upward loop and changing the vent inlet angle so water could not enter solved my water intrusion issue. Check your system carefully for possible water intrusion areas.
Chris1956
So Matt, your plan is to cruise for a while, and then empty the separator canister into a bucket on your boat, refill it with fuel from the tank and repeat?
If so, you will introduce fuel and vapors into your cockpit or need to dump it overboard to avoid that. Both are a bad idea as vapors explode real easy, and dumping fuel is illegal.
I am not sure how you will know when the separator has water in it, and how much. Also, if you wait too long to empty the canister, water will get to the motors.
I still think you will want to get as much water as possible out of the fuel, before you leave the dock. The alcohol in E10 gasoline will absorb some water, so if you get nearly all of the water out of the tanks, the fuel should absorb the rest.
matt167
Everyone keep in mind. Water entered my kicker tank while it was strapped to the transom while on the trailer the night before it was going back out. As most of those tanks do, the caps don’t seal great. My 2 main tanks do not have water issues… but I’m eliminating the kicker tank and adding the water separator because it’s a good idea
matt167
So, no water in your main tank? Good to know.
Nope. The water separator is preventive maintenance. I’ve actually just finished mowing with the ‘recovered’ gas that was contaminated in the kicker tank. I ended up with about 3 out of the 4 or 5 gallons in it after letting it separate and pumping it off
Scott06
Dont expect the filter separator to get all of it out you will be sending chit to your carbs. Been through this on my friends boat bogging rebuilt the carb, that made it through a season and a half before there was an issue again. When I did the carb the first time and dumped the filter in a jar to look for contaminants it showed nothing. Next time it turned cloudy white.
Scott06
I did the same with the fuel out of my 65 pontiac. This was rust mostly but had a 60 year old fuel tank and the car has sat for years. Sucked it out , let it settle and used a paint filter to recover most of the gas. Since this was 93 octane for the higher compression engine I burned it back in the sam vehicle after replacing the fuel tank
Chris1956
Scott, This is off topic for your post, sorry. The water separator only holds about a pint or more of water, before it sends it to the carb or FIs as it fills up. I think that the water separators should be used as a maint item to trap the last few oz of water, if they exist. Water of more volume needs to be removed by someone alive.
Scott06
they dont even hold a pint, so yes you are correct that it wont take much to pass chit
Pmt133
Not a bad idea to catch anything that potentially makes it's way into the tank either. I always treated them more as a mild filter than catching much of any water... the big racor in the 330 I think holds less than a quart of water even.
