Only if the fuel reaches it's saturation point where it can't hold anymore water.Absorbed water on E fuels will eventually separate once on tank and drop to tank's bottom due to water being heavier, right ?
The difference is that ethanol fuels will absorb the water...it doesn't attract the water. A water separator filter will not filter out water that has been absorbed.
++++1but "water" that has been absorbed will burn.....its not until the you hit the phase stage that you run into trouble.
Yes.
