fuel water seperator
BOBBYLEE
I have a 2000 seaswhril striper, and I am trying to find the fuel water seperator location. I have a 2001 150hp johnson on this boat, can some one help.:redface::redface:
clemsonfor
Re: fuel water seperator
you may not have one if you have traced all the fuel line from the tank to the motor and not located it. There not standard or even required, although encouraged.
-nate
tashasdaddy
racor makes one of the best. canister type, i prefer mounting in splash well if there is room. you have 3/8 in fuel lines.
Bobby, My '98 SeaSwirl 21' bowrider did not have a water seperator. I bolted one ibside the bilge, behind the air vent under the jump seat on the port side.
