Gamefisher 5hp water pump question
moparpoolman
Hi, new here, Have a 5hp Gamefisher model number 225.587500 outboard, How can you tell if the water pump is pumping properly? Thanks
welcome aboard
if you havent replaced the impeller in 2-3 years, start there
moparpoolman
how do you know it's pumping water properly? or do you just rely on temperature? What should the temperature be?
mike_i
Is there water coming out of the pisser? Is the motor over heating? Regardless if you don't know how old it is replace it.
matt167
Is that a Force motor? the parts come up as Mercury Quicksilver. Impeller lists at about $100
brim_buster
Its a Force motor and. Its a 1998 long shaft 5 hp. If you see water spraying out the exhaust ports your good. Check ebay for the impeller they are cheap.
