Garmin 740s networking
ricksi
I just ordered a GPSMap 740s and am thinking about adding a GFS 10 fuel sensor. What is the best way and what do I need to connect the sensor to the 740s? Do I need additional NMEA 2000 connectors/wiring or can I extend and splice the wires from one to the other?
dingbat
Re: Garmin 740s networking
You have two options for the installation. If you have an existing NMEA 200 back bone you can connect to that. If not, you will need to buy a Can Kit.
A Can Kit includes 40? of 4 conductor 22 gauge wire and two- 120 ohm, 1/4W resistors. If you can find the cable and resistors locally you can save a couple of bucks. I checked 2-3 places and came up empty so I just ordered the Can kit. $35 delivered to the house.
ricksi
Is it necessary to buy the Can kit? Couldn't I solder the wires using Cat 6 network cable and my own 120 ohm resistors? How does the Can cable attach to the 740s? I'm clearly unfamiliar with both options, but it seems that the NMEA 2000 approach is a bit sturdier. I doubt I'll ever add anything else, would I just need a short cable to attach to the 740s and maybe a tee connector to attach the fuel sensor? I was looking at the Garmin NMEA starter kit, which looks like overkill for what I'm trying to do. But I was curious about the power cable that is part of the kit. Does that simplify powering devices on the network thereby eliminating the need to run power to each device?
dingbat
The fuel sensor has two cables coming out of it. One cable (~6' lg.) is the NEMA 2000 connector on the end. They supply a short pigtail connector so you can wire Can Net to the connector. The other end of the Can Net cable gets wired into one of the data ports on the back of the unit.
The other cable (~25?) is a 5 conductor wire if I remeber correctly. It contains the wires to the fuel gauge, 12V power with fuse holder, ground and the orange accessory wire that get connected to the accessory wire on the MFD. If it wasn?t for the orange wire, you could wire the fuel gauge wires directly to the sending unit and grab the 12 VDC directly from the battery to negate the need to run the cable up to the helm.
There is no reason why you couldn?t use the CAT cable suitable for the environment and 120 ohm resistors if you could find them. I went to 3 different stores and couldn?t find the 120 ohm resistors. Buy the time I bought 20? of tinned CAT cable and spent another $10 in fuel looking for the resistors, I figured I?d be ahead just buying the stuff and having it delivered to the house.
As far as the power is concerned, you need power either way. The only difference is when NEMA, you don't need to run the orange accessory wire to the MFD like you do with the Can Net.
