HT32BSX115
- Dec 8, 2005
- 10,083
Re: Gas Stabilizer?
I didn't think we were talking about snowmobiles and lawnmowers..............
Most of us agree that if you're going to store for more than a year or so, one should just drain all the fuel.
But for the people who think you must "stabilize" gasoline, what exactly do you think you're stabilizing?
Gasoline is made up of components some of which will evaporate if left long enough at ambient temp and pressure. If you place the fuel under pressure those components will not evaporate or "settle" out etc......
One of the reasons carbureted engines become hard to start with "old" gas, is the reduction in vapor pressure that happens over time due to evaporation......lower vapor pressure fuel doesn't atomize as well in a carb venturi......
It's also why carbureted engines are a little harder to start with the newer reformulated gasolines. Newer gasolines have had a [GOV] mandated reduction in Reid Vapor Pressure because lower vapor pressure means less smog from evaporated fuel in the air...... [or so "they" say]..........It's not a problem when low RVP fuel is atomized in a pressurized fuel injector.......
Other "decomposition" can occur but NO snake oils will prevent "high-end" hydrocarbons from evaporating.
It almost appears that the snake oil manufacturers have "created" a problem so they could sell a "Cure"
Otherwise, why would so many of us have NO problems when NOT using it?
I am not trying to be a "troll" here....... but the fact remains. MANY of us do not use the stuff for a winter layup and suffer no apparent ill effects.............
I've had to clean out snowmobile and lawnmower carbs so many times...fuel stabilizer really does work.
I never used anything either. Started using Sta-bil when I got a backup generator as it was recommended in the manual. Now I use it in everything because I have the stuff and I might as well... 4 years ago my dad and I pumped 25 gallons of fuel out of the 80 gallon belly tank in his boat. It had not been used since the 1st owner sold it to the guy my dad got it from, and he had it a couple years. My dad had the boat 2 years before we pumped it, so 4 year old gas at least. It was clean so we ran it in the mowers, smelled a little bit but ran just fine.
FWIW, Seafoam is pale oil and alcohol ( as per MSDS ) That does not make up a stabilizer even tho the cans are marked as such last I checked.
