Gas tank
Newowner2011
My boat is going to be kept outside this winter. Other than filling the gas tank to decrease condensation should I also add Dry Gas to it or just leave it alone and don't add anything ?
I have had it winterized.
642mx
Re: Gas tank
All you need is enough fuel stabilizer for the amount of gas in the tank.
Oshkosh1
Ensign
Re: Gas tank
If it's already full and kept sealed tight...leave it alone.
There's no harm in using StaBil I guess...I don't like it personally...just don't like the film it leaves in Mikuni carb bowls/jets...but hey if it makes you feel better use it. I've never seen the need for it in gas only stored 6 months though.
Newowner2011
Re: Gas tank
I wasn't considering StaBil, I was referring to Dry Gas with brand names such as Heet. It keeps water out. I use it in my truck during the cold months.
Chris1956
Re: Gas tank
Isopropol alcohol (Dry Gas, Heet etc) is not recommended for outboard motors. In addition if you are already using gasoline with ethynol, you do not need to add more alcohol. Fuel Stabilizer is recommended by some.
Chris1956
Re: Gas tank
BTW, The dry gas does not keep water out of your truck's fuel system. It does absorb water so it can be burned and it won't clog up the fuel passages.
Newowner2011
Re: Gas tank
My motor is a 4.3L Mercruiser I/O. I guess I forgot to mention that, oops !! Duh !!!
