Gasket between outdrive and engine
viper1216
I'm going to be replacing my water impeller. It's been a couple of years since I did it and I am trying to remember if I needed to order a new gasket for the job. I know the impeller kit doesn't come with one and for some reason I feel like I had to order one at the last minute last time. Anyone who has done it recently remember if one is needed? I like to have everything on hand before I start. Alpha 1 Gen 2.
Thanks!
Dave
Alumarine
You need part no. 27-94996T2 Drive/Bell Housing gasket set
Or sierra 18-2619-1 which should be available her on iboats
crazy charlie
Not only will you need the main gasket but the orings for the drive shaft and the water inlet also have to be replaced with the large bellhousing rubber oring/gasket.Charlie
viper1216
I think those come with the kit. I think. I'm going to pick it up tomorrow, so should have an idea
