Gasket question (Risers)
JP_R
Hi Guys,
So I need to replace the riser gaskets on the starboard side of the boat and here is my question
Mercruiser 5.0 MPI/Alpha with 3" risers and not closed cooling. SN#0W061980.
How do I now which gaskets do I need? Mercruiserparts.com has the following:
27-864850A02 Restrictor (standard cooling)
27-864547A02 Full flow (with risers only)
I am a little confuser here. Any help is appreciated.
JP
Re: Gasket question (Risers)
Ayuh,.... I believe it goes, Manifold,- Open gasket,- riser block,- Restricted gasket,- riser elbow....
