classiccat
"Captain" + Starmada Splash Of The Year 2020
- Dec 20, 2010
- 3,412
I'm at the tail-end of restoring a '75 70Hp 3cyl Evinrude.
I cranked-it up for the 1st time this past weekend and a warped outer exhaust cover eventually revealed itself (2:38):
It's flat until the last 2.5"...from there it deflects as much as 0.040".
A replacement cover will be here tomorrow; the other surfaces are flat (the thin inner-plate is actually new old stock; the original was pitted & twisted like a pretzel).
My plan is to continue using a light coat of OMC gasket sealant on all 3 exhaust manifold gaskets.
Are there any sealant(s) that you'd recommend over the OMC-stuff for the exhaust manifold?
Also, the last adapter plate gasket that I installed was pre-coated (shiny...sticking to the bag). I ordered a new one and plan on installing it as-is (assuming that it's also pre-coated)...with no additional sealer. Good Plan?
I'm hoping that this is the last time the powerhead is pulled in my lifetime :lol:.
Thanks in Advance!
Thanks in Advance!
