Gasket?
shaun77
On a 1989 125hp Force O/B,when re-sealing the powerhead to the mid-section is there a gasket that belongs between them? I've looked at the crowley diagrams and it looks like they only show an exhaust gasket for the match plate to powerhead.
jerryjerry05
Re: Gasket?
Just between the head and spacer plate. I think the other spot needs silly cone!!J
F85279-2 boat.net about $10
Frank Acampora
Re: Gasket?
Go easy with the RTV silicone. There are water passages under the match plate that can be clogged by too much. A light coating smoothed by your finger before installing the block will do.
