Gauges fluctuating, bouncing around
Laneman25
2001 Monterey LS190 with Volvo 5.0 GL, Chevy 305. Tach has a mind of its own, sometimes reads normal at idle, then goes up to 3,000 RPM by itself. Fuel gauge drops suddenly from Full to 3/4, then right back up. Volt gauge reads a constant 12.8 while running, but I don't trust it.
you have bad connections. start at the battery, remove, clean and seal every connection all the way to the helm. pay attention to the ground buss under the helm.
