Re: Gear case oil fill mistake
Ya, you are okay I would just remember to change it before too long just in case you get a leak.
Gear oil and lower oil are almost identical except the lower oil has additives to deal with water intrusion so as long as you change it again this year you will be fine.
I have gotten in the habit of cracking my lower drain plug every other trip just to check for water, oil comes out I am fine, water, the lower needs attention.
