As PNW mentioned, there is no clutch for smooth engaging it is all pure mechanical, metal to metal engagement with clutch dogs. So instead of easing it in, be snappy and always put a little gas into it when engaging. Idle speed is also critical as the higher it is the more likely it will grind not to mention it can cause untimely wear out.
