Jburke4689
- Feb 23, 2014
- 5
I was doing some maintenance on my lower unit. I replaced the water pump assembly, the propeller shaft seals and the bearing carrier O-ring. The unit was not leaking before I did the work. It was just 14 years old and I was doing preventative maintenance. The unit was filled with oil and I laid it down on its side where it sat for three weeks. When I lifted the unit upright today about one ounce of clean gear oil leaked out of a small vent hole in the side of the gear case and the water intake.
Nothing is coming out of the seals I replaced and the ones I didnt replace (driveshaft and shift shaft) weren't leaking before. The unit isn't overfilled.
My question is whether it is normal for some oil to leak as described if a lower unit is laying on its side for several weeks. I plan on pressure testing the unit before reinstalling it. Thanks
