Gear oil pump
bobhol
I hate using the little plastic pumps to fill my lower units ..I now have 3 to look after...Is there a cleaner easier way to fill ...something in a gallon container and using air pressure or a better non leaking pump....any home made solutions? ..thanks,Bob:D
Bt Doctur
Re: Gear oil pump
Mine is the pump for the 5 gal pail. If leaking from the drive fitting, try using a small O ring on the adaptor .
Don S
Re: Gear oil pump
Those inexpensive garden sprayers with some judicious adapting of fittings to the end of the trigger works great. 1,2,3,5 gallons.
Re: Gear oil pump
Ayuh,... I built mine outa a 1 gallon metal can sprayer, the metal adapter off a qt. bottle pump, 'n a 1/4" ball valve...
bobhol
Re: Gear oil pump
I like those ideas...off to the workshop...(think my wife will miss her rose sprayer?)..thanks guys!!:)
bobhol
Re: Gear oil pump
A related question...can I use the same mercruiser hi performance lube in a honda outboard and a suzuki outboard...:confused:
