gear oil
Haut Medoc
Re: gear oil
Mercruiser gear lube is ten backs a quart, once a year.....
You must really be on a tight budget.....;)
Mkos1980
Re: gear oil
Ditto to the above, MerCruisers high Performance Gear Lube is where its at!
sickwilly
Re: gear oil
Quicksilver high performance gear lube for me. I think its absolutely the same stuff, just a different color bottle and sold somewhere else.
Re: gear oil
Ayuh,.... Any good clean hypiod oil will Work,....
Personally,... I see the Synthetics worth the extra ca$h... I run Mobil 1, in 75W-90....
