I have a 90 hp Mariner serial # OG143399. I had some problems last summer with it popping into gear while I had it in neutral. Recently I changed out the impeller and fired it up but it stays in forward gear no matter where I put the shifter. (Before I took the lower unit off to change the impeller, I turned the propeller with it in reverse, neutral, and forward. Reverse was a solid hold, neutral was okay, but forward would just click as I turned the propeller). <br />I took the lower unit off again and notice that no matter which way I turn the shift shaft on the lower unit it stays in forward gear.<br />The shift shaft from the powerhead does turn when I shift the console lever so that's okay. Is this a stripped gear problem? Is this something a marine tech should handle? Thanks for any advise.
