Re: gears how to know
7500 RPMs seems a bit high. I turn my 125HP up to 6000, but that's about it. Maximum manufacturer recommended RPM is 5500 RPMs. I suspect that maybe you had a 1.73:1 leg and now you have a 2:1??? I don't know but 7500 RPMs is pretty high. Sounds like you are under propped. You might need to switch to a 17 pitch stainless prop to get your top end back.
It's been my experience with the setup that I've got that the 1.73:1 gear ratio gave me a poorer hole shot and less top end. That is with a stainless cupped 17 pitch prop. Each hull design and motor set up is a little different for everyone, so my situation may not necessarily apply to yours. I switched to the 2:1 gear case and haven't looked back. I used to use a 15 pitch stainless cupped prop with the 1.73:1 gear case, but since I switched to the 2:1 leg, the motor turns way above max recommended RPMs. Now I use a 17 pitch cupped stainless for most of my boating. Max RPMs with this prop is 6000. I also have a 19 pitch cupped stainless for long cruising. Max RPMs is 5000 with this prop. Hole shot is not as good though.
Bottom line, I think you are under propped if you're turning close to 7500 RPMs.
