Gel Coat numbers anyone
rokrau
Hello,
I recently purchased a 2002 V210 and it has a bit of "dock rash", lots of deep scratches that won't come out from rubbing and polishing alone.
Does anybody know where I could find the gel coat numbers for this model year?
Best Regards
--Roland
rallyart
If you contact Sanger with the hull number they will likely have the gel coat numbers, and maybe even product, to match your color. It is a small company but they keep pretty good records.
jbcurt00
But as the 'old' gelcoat is 15yrs older, has been exposed to UV and whatever cleaners/wax over a 15yr period, even a perfect number matching gel may not match the existing. It will also fade at a different rate then the existing, so in a year, the patches may stand out any way.....
Good luck
Got pix of your Sanger?
