gel coat over epoxy ?
JJB
I wanted to know if you can gel coat over epoxy or do you need to use epoxy paint ? thanks JJB
Mark42
Re: gel coat over epoxy ?
I looked into this just receintly. I found that the options are paint, or an epoxy finish coat that can be colored. Look at epoxy suppliers for the product.
ondarvr
I've called West Systems about this, they said well, it does sort of work, but might not the the best way to do it.
I sell gel coat and my answer is never use gel coat over epoxy. I've tried to get a good bond before and while you can get it to stick, it was never a strong bond. I was never able to get a good enough bond for me to be comfortable with doing it on my own projects, or for any body else.
By the way, all our chemists also say it's not a good idea.
JJB
Thanks for the replys . Is there a epoxy paint that I coud use on the top side as well as my transom area also ? The boat is always on a trailer ! Thanks JJB
