Gel coat repair
jumpjets
I have some chipped gel coat underneath my boat hull. What products do I need to fix it?
I would mix up some thickened gel (gel tinted to match, fumed silica, some wax and MEKP)
sand the areas with 80 grit
clean with acetone
mix gel and fumed silica into a past
spread in and fill gouges
wait until it cures
sand
then if needed spray to blend
last, but not least, buy a keel guard
jumpjets
Do you recommend buying a little gel repair kit, or getting the ingredients separately?
JASinIL2006
I bought one of those gel paste repair kits. It had several tubes of thickened gelcoat, catalyst, and tubes to help you color-match. For a small gouge like that, it would be perfect. I believe iBoats sells it. Evercoat Gecoat Repair Kit.
after doing a few hull restorations, I simply buy a quart of gel when needed. I have everything else at home. Gel has a shelf life of about 6-10 months.
jumpjets
The gel coat repair kit worked perfectly. It had more than enough to fill in all the gouges. The patch job isn’t perfect but it’s good enough. I’m not a talented body-man in hiding.
