Gen 1 or gen 2 outdrive?
johnnyrich10
Hey guys i am getting ready to change bellows on my out drive. My boat is a 1983 Chaperral with mercruiser 260 that i just rebuilt with what i thought to be alph one gen one outdrive. during rebuild my buddy that rebuilds engins said it looked as if it were rebuilt before. so i purchased a impeller for gen 1. it is completly differant, the housing on the water pump covering the impeller is stainless steel, and i was told those were only on gen 2. So I was told that the u joints bellow is all that is differant, so if mine is a gen 2 i need to change my order asap. ?????????
Thanks guys
johnnyrich10
Re: Gen 1 or gen 2 outdrive?
so my thoughts are they replaced outdrive too. i am at work and unable to get the numbers off of it. are there any pictures or anything of the differances to tell? i took it apart last night so should be able to tell. And another question, could just the lower unit of the outdrive have been replaced? prob a dumb question, but i am a noobie
muc
"Retired" Association of Marine Technicians...
Are the upper and lower held together with bolts and nuts? == Alpha1 gen2
Are the upper and lower held together with studs and nuts? == Alpha1
johnnyrich10
Looking at the pictures my unit seems to be a gen 2. It is held together by nuts and bolts. Thanks for the help guys.
Don S
Nothing between the two drives and transom shields are interchangable. except the gimbal bearing. But who is to say that someone with access to a machine shop didn't hand fabricate a bunch of parts to make it fit.
johnnyrich10
I believe he was just talking about the bellows and gaskets.
