Hey guys looking for some suggestions here
1985 fourwinns horizon 195 cuddy has factory mercruiser 260 5.7 V8 and alpha 1 (1.5 ratio)
Currently running a 14x19p stainless Propeller and wanting to go for a 14.5 or larger diameter or a 4 blade prop as I have alot of prop slip at slow speeds
Problem is the boat revs fast to 4,000 rpm but I can't get it to go over 4,000
Off the line the boat will rev up to about 3,000 rpm till it plains than make its way to 4,000 rpm and a top speed there of roughly 45mph
I can get there at 3/4 throttle but the last 1/4 throttle makes no change in rpm or speed but you can clearly hear the 4 barrels open up (bogs a bit too when it does than comes back) and the engine tone changes but no more rpm
So far I've done
-compression is all 145-150 psi
-new ngk plugs gapped .035"
-new Sierra coil
-new 10w40 Pennzoil maxlife oil
-new Sierra fuel filter (10 micron)
The boat is a little hard to start dead cold but the choke was removed and has a manual lever for it now so that could be because of that
Once warm the engine starts near immediately, repeadibly and idles completely perfect about 700rpm. Engine never stalls out even with alot of idle/forward/reverse work at the dock or extended idling
The motor runs with no hiccups besides the 4 barrel bog around 3/4 throttle which I read alot of these Rochester carbs do
The wires look newer and are in great shape no dry rot or tears
Moroso electronic distributor looks good with no abnormal wear
Boat also has an edelbrock performer manafold if that info is helpful
What should I look at next? Could there be an exhaust block? Maybe need a bigger flame arestor?
Could my 10 vs stock 20 micron fuel filter be restricting flow?
Idk where to start here as I really want to see what this boat does past 4,000 rpm I read my boat should be around 60mph at full proper wot rpm (46-4800 rpm)
So far I've done
-new Sierra coil
