Gimbal grease
harojs
I have a VP SX 1.66 on a VP 5.0L with greasable gimbal bearing.
[Q] How many pumps ( std. cartridge ) grease should one pump in using external zerc fitting for yearly maintenance?
i.e. doing blind pumping with leg attached, motor running.
Can anyone with their leg off do a test for me?
John
Bellevue, WA
Ayuh,..... 10 pumps will freshen the bearin' grease, without overloadin' the bellows with purged grease,......
harojs
Thanks, I don't use enough to pull leg every year. I have shop do a full drive check every couple of years.
jerryjerry05
IF??? you use the boat once a year you should still pull the drive.
How often for an oil change?? :(
