Re: Give your opinions on attached 2 vs. 4 stroke article
Bahamas? Dang....we still have ice here! And hey, that old Honda 4 still runs like a well oiled sewing machine.<br /><br />FlyBoy, your example is a fantasy motor. $2,500? 18" tall?<br /><br />How about we use a real example. Lets compare the Merc outboards and Merc sterndrives of the same hp.<br /><br />A 250 hp Mercruiser stern drive engine in the most compact and popular 5.7L version available, complete engine ready to run will cost you about $8,000. This is without the gimbal housing or stern drive (in other words worthless). Want an Alpha 1 outdrive? Thats another $3,000. Then it all needs to be installed. I bet you can't get the labor for under $1,000. Want fresh water cooling? Add another $1,000. How about engine mounts, wiring harnesses, controls, gauges, intake ventilation, blowers and exhaust routing? Another $1,000?<br /><br />When its all said and done in the water, lets round it off to $15,000.<br /><br />Did I mention this thing weighs 938 lbs with the little Alpha 1 outdrive? It will sit 22" high, so with clearance from hull bottom for oil changes and adding the cover/cushion height, you're looking at over 30" tall.<br /><br />The 250 Merc outboard can be bought, installed, and loaded with all the goodies for under $15,000. And it will weigh only 479 lbs. Plus you won't trip over it. It will be safer. And if you don't like it and want a 300 hp or a 50 hp, you can change it out in a few hours and make the next tide.<br /><br />Ever try to fit an inboard in a 14 foot Lund? How about twin power for safety....2,000 lbs (938 lbs X 2) of inboard engines or 1,000 lbs (479 lbs X 2) for outboards? Which one will be faster now? Need a tiller engine? Not with an inboard. How about an interchangable jet unit? Not with an inboard.<br /><br />Come on FBM, sterndrives have their place, but so do outboards.
