You may be right. But it’s a shallow hull for sure.
just checked there. It has a pad too.
Well the pad is your salvation. All bets are off with that....you may see your aspirations!
Big guns on here used to flaunt 1" jack for every 6" of setback, not from the transom per se, but the aft extent of the wet hull, like some BB and other boats are offset (cut back) 6" in the hull before you put a jack plate on it.
My first bow lifting experience, where the boat left the water was a new 1989 17'6 Ranger Fisherman which was a Ranger style Bass Boat hull, but narrower, with a deeper V and the pad, rigged out for Back Trolling like they do here up North for Walleye and maybe Pike and Muskies, even Striped Bass, or crappie fighing brush piles down here. Bought it from a big dealer in Dallas.
Had an original Laser SS on a 115 "Tower of Power" and she was a 50+ boat On my shake down cruise, she started chine walking at 55 and I backed off the throttle. Didn't look at the tach as I was busy wondering "wondering where do I go from here). As I recall the Laser was a 24P which makes sense since that's what he put on his popular 150 HP Bass Boats and had them in stock....sold very few 115s. I took the prop back to him and he ordered and got in a Laser 19P for me as I recall, which I never took off and that engine had no problem seeing 6k with it and loved it. Being ported (ports were round and ⅜" recollecting, on the original Laser) I could hammer down on it in the hole and get a good, fast, shot, then up at a good speed as I was trimming out, the prop would lock in, the boat jolted when it did it and I took off.......grinning all the way.
I used to love to hear it singing and the blades of the prop hitting the water making a humming noise when I was hooked up and on the sweet spot. Trim sweet spot was out till RPMs started rising and speed started dropping off.....tucked back in slightly till the numbers went back to max.
Rangers had a pretty much zero tilt transom angle and had the 6" hull offset....inset really, so they could take the angle out of the transom which most mfgrs. have to get the LU out from the transom for less ventilation I guess. With the shallow transom angle you could get higher trim angles without running out of trim (the 20 degrees on Mercs). The other thing, as I see it, by having a deep V and the pad, once on the pad, the spray is clear to exit under the boat (out the sides) as there wasn't any hull in the way to deflect it helping to maximize MPH. That was my first boat that I felt lift off the water and had fun with it....didn't need to do any fishing, just play with it.
This wasn't a hot dog Cigarette go-fast boat or any of that....just a middle aged guy (at the time) with a new, stock, fishing boat experiencing things never experienced, having a great time.
