Glen-L WB Power Skiff Build
zool
Thanks guys, trying to keep things moving along, eve though its getting cold again.
I figured i'd add some tabbing to the outer hull edges before fairing to make sure things hold together i rough water.
y4m1AL-4lUpyzSkaeiIXSOL5uoKZYdYx5RKBL94nAEpEEPkvySvp7lFv7ycJTK4oiZTkOup6Z_sKJqPZFpJFpSge9hmSOikYrUA5D-iVSPELxSrAsRhODuirw9fTiiODfITIH5EW_o-ArkQHF5es9CtDtilSDUgfvAvjOghorZm8o8MeRmIb-t8uxzc5-ql3NeH6Kw_QcjeqfaK55UQ5GuRcg
y4mqDiziyBKlG7zdIy6cbnDqyDraZrtUkW5W_4dRm45DI5hJi8E68LmygSryOJH-SSeTa8YwDbPwksCASdSfWs9IEV5QJcyxRZSBY8tbtHgrnD1NWSZoJ3pCqcW9znnJORkIDJwGIT7hQM9Pd0gh0Yr4mVT44dgUYWiXgCCbQtgsl2Y-5mC2n2gvJA9pCjPqLAL87fknpirNtRKCHwCyqFfYQ
y4mYbBR7usKhN19XpjAbF-qg9jP8RjoqOFjZ2i8nFM89jzZkbnLBqT6IfQ9qRY9rv78yGL0yQctaYcWg5dDpM02Vz2AxHxixYMRONFUmE6CrVYgw6S3tObHW3h6irjPTUxfZpltHRdMHuwiDartLl2ublmebgWMp7ATl3JOTsUiUWiXltIUKDfpPKF88xNT5HD0HAH1cdL4OoYME2mCQCQ7Zw
zool
I also trimmed and cleaned up the edges of the transom planks, and pb's around the center wood rail.
y4m1R6PTXaEPD_KATP-miBLwpYl71LQ_iUf52GQ7iyl6RZAwJ0BSqm2EWT3gpxRxKpciz3Jx3L3qgfjVRd69zVBpiZZwMcVKVqzwf82gVLZSSCwNAtKZonXDLxjyv4S5zb1vLN5L3h5Fqg1gv1Panx4jDTxBH2Yqn3Ws2GXWTrsaT6vhLiCcan3ULAOtyxR20hqM4Pns9TqbspvHTEFVnRzsA
y4mTkjQx1tjySpEPIQ0A82iBaltJB_KIsqnVQB8bbbKMreiE5d-wsXdgGUYh7mCIFBY4Ft3_UeStP1b1fgYC08u-KJ-X953d6NMBA4q4adGOFOAijt58A8YPn-h3ph8Sm7Q_pR7afR1RT3d-6TZe70f_opsNcS1t4y-g-Hptd7OonKLg0joqEOTsz7NE298TCyxs-aAHlyLDy7ujlZYbU6EFg
zool
It was cold today, so I used the lamp to heat the resin, ad the torpedo to heat the work area.
y4mREW2pUCx4NWdm1Fl0M0hA0T0y3QV_2Ec3Jul3x4_H4TItQwPTi5NNDOgjRQRYXZYikGTfdPMhs0xY0a4fL2h-FFrGWHsFObL81P5C7b9a7XPYyOKIidZUAwM7ZOhiRzq-2K81GbYNxBlEIJyId1EgnXx90G8y__u_MFxYXQ9TuM1Z2akgokFnvM9931t01GWxbkcNGyCNGT8vQTo6ruBbQ
y4m3b52nRpfo1e_iPdtn3CklRPBr4slESt7s3ojNe0viJTiK7M2K988Y5FZqj7azZQh-04Lb-4etoMGhUnLaNF1JueDxdhcd5o0vexf8tDeywd8TM20-ocC5wSOR91NzSTBmiLRltc4m7tdf1RPijVZTAC8tDNEwH_XJP3Dr33gDQSdT_116gGnCw34bvTgnW3cfFOD7EAcSE-lWtr_crlb1A
zool
Yesterday I moved the final motor out of here and into the other building, and with 2 large outboards, the 2 aq171's from the Imperial, the 5.0 and trans from the Monte ss, and all the outdrive assemblies, it was crowded to say the least lol, so temporarily put the cap back on the checkmate, and moved it in with the skiff to work on
y4m08sIUB_-4Xxzd92hwgbh2hnk6BlTSd6qsENc0oHOib5PF5Sdyy8ISaZPbDDiY8rrv16cmFzRAFsXFdUvETgC43WOzA6Y6hOyYIBNJDo-OIt2mvCbxasbmyix6T6hE6lB3IHF1lqOjrdmHMABm9un-xQ7Th0gc4NC3lNGBFUZRMnb9jz6cV1wZyer7Lq-JolThoOw7lEP4pWLmMN0ShJsuQ
Gonna build another rolling cradle for it.
chevymaher
Well while your having fun I am shoveling snow LOL. I much rather be doing what you are.
zool
We were supposed to get snow here today too Chev, but it stayed on the coast, dodged another bullet! ;)
chevymaher
It isnt as bad here as it was supposed to be. I just went out and shook the boathouse roof to get the ice and snow off. It is sleeting and snow mixed now and supposed to do this all night.
mickyryan
just wanted to point out what appeared to be some gnat exrement in that fuzzy out of focus pic on board 4 on the starboard side.... looks awesome so far :)
zool
Yeah, those damn gnats are always taking a dump on my boat! :mad-new:
nurseman
You saw that too? I wasn't going to say anything...didn't want to upset Mr. Zool.
But it does look pretty sweet despite the piles of crap all over it.
zool
Im thinking maybe that was the missing ingredient for the stain color...
revised formula: Cognac, Bombay, and Excrement. ;)
zool
Update:
Today i went out back and the epoxy cured enough to start working on prepping the bottom for fairing.
The hull edge tabbing was full of unraveled strings and resin puddles.
y4m4ICAzoCYyhK4DKeztHs6CCtfPLaW3cK8QuuINVGJPtTF2ZYc6zbkQJUWNiQxlnwT9Uj-dCUmbkwExHRstGvLDYQs6thMKuHBsAeKRyKxqPb6dKe_F4f8upGpwZPWvtXwpiTVEJgv4zc8rrslDUdFPxdaQtCSDxqpjWtKssS2PFb1iX6rw2JQJn5FurHsbwT_YZKNHqArBEKYu5yIsJlMcQ
I started working the areas from the stern forward on both sides with various power sanders.
y4mzhKtBPb8PNsQAw1k3NXCpyXSFrYxfkjw9nElExlhdiQZ2UjFwioPcBRQs3lgii_dzCf2_SQGYy5R-ObjDHVmtZ9ZnRojtnoztPA2APSszs_x4HO5ck1OughkxSXzcNuJFf0n6m83hK_xagQcCi4_gQwkaPReLDMVLAaHuykcIxQznAJlNlPlI5DmG1VklvrGu4yVujJVZ-b6uqMJ6Ltydw
Started with 60 grit up to 100.
y4mFD_gbqhtLXaQVJZGV-FVDqk8-6tLZU94mdu7rANW0_7EOBCxiozjb3iS9MHgfpLnrycW4fvMSzFpMkUafRHTdyR5ucwCR-ucMMA9cM0Hcx6CyI4OnstwSB2eD1qkqMcV_djtetuW5XhJOXWcFV__odxXlRhPSEd7BZ7od7JrRx8vYd70YuDbRHH4Cg6DRbTvtDf1pgjwROx9aVtA-l-Xaw
zool
When I got most of the cloth feathered out, I switched to hand block sanding with 150 grit. I also cleaned up the glue edges on the keel.
y4m3Tu3bqjTsQsMkX1lYlHpOukvwPaiRGQdKiDPF-Dza-QrxpkLlRo7EFYxvLBMX-DQ-IYvJm2Vjd8roV_qOXx_rptdNzHFKG4AlP37fmU5b6wX9rpLsj-TKiZBUJ7kwdJuGVvRMCiRP69_N47Qnf96XB9AOWgzQW0ciJq9DZZVP5NTHhmFbOABKykUXaPJQUEXnjMCRFiaFVtGapXQ3wSK9g
Worked it till the cloth completely blended to the hull.
y4mo_-zQJijTJaRQCto-n3HmGRoDxDT_ZvnQVxTnJVu-FCQlQTuOmQU5ePxjqpsmhIgKjM8OW0X9fZZqTrrbzQiqQeV04GcDLKvk76MEDo4195mOodz104e3FFTeilkdfuUM-OdWyQ01uvfEWTqqa3h8oD1nd0cl0EIsERLRmg6vY_UGZquxJbIDExKVFtCQ7ncr_Rt7cP4DHyt6uyxSbEZxg
y4mNgZRFAiw8FlxV5tsFMITMzTs4tUynUC9NYcUwG2PYPG9IMubtE8gZXcgxQsccv1aN-bbB2SkJXHEw1Z5TnntiFcVzSzUQsHZ7KwLXUQD58LDpKcXPgdJ1hi6yiwhGAQyNDEULTn2GS2BjWZ23ej7wXNqLeIB99kNQMiMvvtxujERPudYIR7V8BRaAPVxi4iZIyqGBXCwKlSx6ckLgzfBFg
Got most of the bottom prepped for a leveling coat of compound, then a final skim coat.
y4mlTenlMv5rp12hKh7eZKadIuWv6OQInRPLZOLbkY3xISYO9GeZfGon0B8IV6p4DZ-quqBxBtyFzxms7s_ahxHMZYVlUjOMyvSnYQiMRJL4x5w95fbO__8EDMQ43Kvqo9XikCkle0PeVgrAYi3GaH5PxYu8CePWOx_bf_JT86S5KSCeb_ZFL0NzmoDHY8j-LNCdsHhIjbJenMBVBact3XhFA
Had enough for the day at this point but satisfied with the results, I hate sanding epoxy and cabosil almost as much as grinding glass lol
zool
Thanks guys, Kev, im pushing to get it done because I have to have it inspected by the State Marine Police to get a hull number so I can register it..never done that before so I dont know what im in for.
Pcolafisher
Does Glen-L provide assistance with what to expect from the inspection? That could help.
Cheers
