Gluvit or not
backlashed
I filled my hull to just above what should be the water line, and let it sit for about 4 hours. To my surprise I didn't have a single leak.
My question is. Is Gluvit a future leak preventative, or just an existing leak stopper?
Is there any need to Gluvit a hull that doesn't leak?
jspano
Re: Gluvit or not
what kind of boat? will you be able to do it later if you needed to ?
if not do it now
Bob_VT
Re: Gluvit or not
Works as a preventative to an extent too...... since you are down to the hull it certainly would not hurt to seal things up
CBGale2
Re: Gluvit or not
Id go for it while you have it gutted, its not bad to put on and well worth a little extra peace of mind.
