Hello everybody
GM 305 year1980
May someody tell me if 4.7V on the + of the coil is enough ? Where is the resistor and how many Ohms should it be?May it be inside the solenoid at the back of the portside manifold (because i have the 4.7V at a pin of the solenoid?
When the engine warms up and you try to run it behaves strangely.As some cylinders do not work properly or at all.Spark seems weak but i don't know how is the proper one.I 've changed fuel pump but nothing.An electic diagram would be very helpfull
Thanks in advance
GM 305 year1980
Thanks in advance
