From what i've gathered online and from a Haynes manual, I need to support the lifted front chassis on stands and then apply lift w a jack to the lower arm to remove some of the force on the upper a arm. Then I can unbolt it, and pull it off the spindle, and hang it up, out of the way,w the shock removed of course. Then unbolt the lower BJ and hang the spindle out of the way, and knock out the old bjoint w a hammer, I have a 4 lb, then press the new ones in w a tool loaned from AAP. Am I missing something? Are'nt there some C clips to hold the ball joint in place? It sounds too easy...........I'm guessing i'll have problems Knocking the original ones out or something else will need replaceing also. I have already replaced all the steering linkage parts last year. I plan to do the uppers later, unless they seem too worn when disconnected from the spindle. I'm not looking forward to the removeing uppers factory Reevits
