I lost electrical power yesterday while cycling the ignition switch from "accessory" to "run". The audible chime came on for less than a second when I went to the "run" position (noticably shorter chime), then nothing when ignition switch shifted to "start" position. All console power was out as well as the ability to control the trim motor. This is key as the trim motor works independent of the ignition being in "off" or "run".
There is 12.8V on both batteries as well as at the starter solenoid contact from the battery. The 50 amp fuse on the 5.7L VP has 12.8V on both contacts. Is there a relay or another fuse between power source and cannon plug? If so, where is(are) it(they) located? I have no power at the console fuse box or at ignition switch contacts, therefore I deduct the loss of electical continuity is between the starter solenoid and cannon plug. Any advise is appreciated.
